1984 5000S Hard starting, runs bad cold, and diesels!
Old Aug 14, 2007 | 07:45 PM
Phaedrus44's Avatar
Default 1984 5000S Hard starting, runs bad cold, and diesels!
I've posted this question before, but maybe I can get a few more opinions.
My 5000 2.2 liter runs great, never overheats, gets good mileage, and passes smog after it's all warmed up. However, it's hard to start when it's cold, and takes me holding the pedal down to get it to idle until it warms up.
I've done a bit of diagnosis, and I do have the Bentley manual and quite a bit of mechanical aptitude, but I'm stuck. I removed the cold start injector on a cold day and craked it...and got nothing. I think my problem may be the thermo time switch, but I'm not sure how to test it. Can I stick the wires together and try to force the cold start injector to go, or should I try somewhere else?
Also, the car always diesels badly when I shut her down. It's runs on real fast for a couple few seconds...sometimes backwards. The car's been treated well it's whole life and I just replaced the rotor, dist. cap, plug wires and plugs. Could the two problems be related? Thanks...
Old Aug 16, 2007 | 03:03 PM
InExile's Avatar
Default RE: 1984 5000S Hard starting, runs bad cold, and diesels!
you could have a problem with leaky injectors ... the injectors are supposed to hold fuel pressure, but if there bad they leak -> no fuel pressure -> lots of cranking required before fuel pressure biulds back up ... and also check for vacum leaks
joesaudi1
Jun 29, 2015 11:51 PM
Dennisyudich
Nov 4, 2012 01:18 PM
felixvg
Jan 7, 2010 01:07 PM
Phaedrus44
Jan 1, 2007 06:53 PM
Phaedrus44
Dec 10, 2006 12:47 PM
