1984 Audi 5000s Cold start/warmup problems
Old Dec 31, 2006 | 08:16 PM
Phaedrus44's Avatar
Default 1984 Audi 5000s Cold start/warmup problems
Hey group,
I finally had time to try to check the cold start problem with my 5000. It's very hard to start cold, and requires me to hold it at about 1500 RPM to help it warm up. I have the Bentley manual, but it's diagnosis procedure for checking the cold start/warmup systems is hard to follow.
I removed the cold start valve and cranked the car...nothing. I checked for current across it's wires...nothing. I removed the connector on the upper temp sensor on the thermostat housing and checked for current while cranking...nothing. What should I check next? The manual says to check the thermo-time switch, but I can't even find it. Thanks in advance for your advice...
-matt
Old Dec 31, 2006 | 10:27 PM
kakarot's Avatar
Default RE: 1984 Audi 5000s Cold start/warmup problems
thrmo time switch next to the temp sensor. there is 3 sensors, and they are in same peace. its on the head, and the tube going from there to the rad.
Old Jan 1, 2007 | 06:53 PM
InExile's Avatar
check also for broken wires and the condition of the connections .. clening the terminals will not hurt at all
olsonm3915
May 16, 2008 08:11 AM
Phaedrus44
Aug 16, 2007 08:49 PM
Phaedrus44
Aug 16, 2007 03:03 PM
audi5000S85
Feb 14, 2007 08:53 PM
Phaedrus44
Dec 10, 2006 12:47 PM
