1989 Audi 90... newbi Questions
Old Nov 26, 2006 | 04:46 PM
Frenchie's Avatar
Default 1989 Audi 90... newbi Questions
I was wondering if anyone could answer some questions:
1) How hard is it to replace a starter... Does anyone have a tutorial or a walkthrough
2) I know the rims are 4 bolt but will any 4 bolt rim fit on it?
3) What type of oil does it take?
Old Nov 26, 2006 | 04:55 PM
techbod's Avatar
Default RE: 1989 Audi 90... newbie Questions
stater motor fitted from under the car is best ( more room ),
wheels well have a look its all down to the PCD
http://www.performancealloys.com/all...s_adaptors.asp,
oil should be 5W/30 semi synthetic but you could go full synth 3W30 or better
Old Dec 1, 2006 | 09:41 PM
TommyL's Avatar
you can get a universal 4 bolt, those should fit.
The ones that have eight holes
Old Dec 17, 2006 | 02:03 AM
Frenchie's Avatar
I got the Rims and the oil all sorted out. I got a new started put in today yet the car will still not start. It only turns over and clips but the engine will not move. Does anyone have any idea or suggestions?
Old Dec 18, 2006 | 01:02 AM
kakarot's Avatar
like, the engine turns over, but does not catches. or you hear grinding noise, and engine does not turn over?
Old Dec 18, 2006 | 03:26 AM
Frenchie's Avatar
The engine will click yet it wont catch...
Old Dec 18, 2006 | 11:44 AM
techbod's Avatar
flatbattery
Old Dec 18, 2006 | 04:40 PM
Frenchie's Avatar
The Battery has been changed as well....
I know the previous owner screwed with the Distribution Rotor, What should I look at in order to make sure that the DR is installed properly...
Old Dec 18, 2006 | 04:47 PM
techbod's Avatar
hmmm the FD wouldn't cause that sort of problem it could still be the battery down on cold cranking amps, try another battery or get someone ti give a boost from their battery
Old Dec 19, 2006 | 03:39 AM
Frenchie's Avatar
Thx Dave. I will try a new battery tomorrow and let you guys know how that goes ....
