1995 Cabriolet top problem
Hello once again. On my 1995 cabriolet, when I push the button to let the top down, the light flashes, but nothing happens. I can put the top down manually without a problem. Any I deas where i should start to troubleshoot. P.S. There is NO movement or sounds at all as if there is no power to the top.
Thanks to all |
RE: 1995 Cabriolet top problem
I have the exact same problem, with one slight difference: my roof light flashes for about 5 seconds when I start the car. The previous owner operated the roof manually for the 4 years he owned it.
I have read through posts here about cabriolets, and I am thinking we should start with the relay, and check all the wiring. Does anyone have any advice for us? Thanks very much! |
Did you get this fixed in the end? what was the problem??
I have got a problem with my roof where the back storage only raises less than half way and then gives up... Any advice would be massively appreciated... Cheers, Mark |
i have the same problem also. but mine lowers both windows half way.
