20vt vs 10vt suspension
I have an 89 200 10vt and i was wondering if the suspension on the 200 20vt's were the same... The suspension on my 89 200 10vt is pretty bad and i want to replace it but when i look around all i can find is suspension components for the 20vt 200s.. so really im wondering if i can buy stuff for the 20vt 200 to put on my 10vt... or if anybody knows where i can get 10vt 200 suspension components??
http://www.audiworld.com/model/200/89-200.shtml
That explains the suspension which I believe is diffrent..
they should be no different.
its the same car. just diff motor and a bit newer...
according to audi world heres some help.
91 200 quattro
Independent four-joint trapezoidal arms, coil spring/shock absorber struts
89 200 quattro
is it quattro or FWD?
91 200 quattro
89 200 quattro
Its quattro... well i decided to turn to motor geek, since there bigger over there. but apartently the fronts are the same but the rears are differnt and then the ball joints are also differnt size. Well i have all my stuff ordered and if anybody comes across this tirerack has KYB GR-2s for cheap but they dont have the rears for the quattros, while 034 motorsport has the rears in the KYB GR-2s for cheap oh and then springs that i got were H&Rs again tirerack was the cheapest... and i did alot of looking around.
