84 5000
RE: 84 5000
Check the compression, you probably don't have enough of it. You need a minimum of 125psi to get things started with difficulty. If the car sat outside, rust has formed on the cylinder walls and valve stems.
RE: 84 5000
ok, got it runnin, woohoo, but it just doesnt have any go to it, i dunno if its because i made a drastic change in power from my last car to this one or if the car is actually that slow. Btw my cylinders have about 165 psi in the cylinders, but had replace ignition system and adjust the plate in the airflow meter thing in the intake. And does anyone know where i can get a turbo for this P.O.S.?
RE: 84 5000
installing isnt a problem unless its more involved then puttin a turbo in a japanese car, if i can get the turbo thats ment for this car that would be awsome but i just dont know where to get one. if anyone had any suggstions on anything that can be done to this car either a turbo or a air bag suspension kit, or actully anythig, that wuld be great. thanx
RE: 84 5000
If you are talking about something like a turbo kit for a Honda Civic then there is nothing like it for the Audi 5000. You will need to find a donor car on ebay, junkyard, local classifies, and transfer all the parts.
