87 Coupe GT 2.3L motor - support points?
Old Aug 15, 2015 | 03:34 PM
KPDET's Avatar
Default 87 Coupe GT 2.3L motor - support points?
I am trying to replace the oil pan gasket. I need to remove the subframe and support the engine. I have a crane, but I am not sure where to attach it to the engine. Any help is greatly appreciated. The Woodward Dream cruise is happening today here in Detroit. What an amazing scene!
Ken
Old Aug 24, 2015 | 10:38 AM
dave944's Avatar
Yep. You'll have to remove the subframe. But the front engine mounts are attached to the body. The transmission mounts attach to the subframe. All you need to do is put a jack or come blocks under the transmission to keep the engine from sagging at the rear.
Old Aug 25, 2015 | 08:12 AM
dave944's Avatar
Upon further review, I think it can be done without dropping the subframe. The rear pan bolts might be a little hard to get out but there may be enough wiggle room to get them and the oil pan out. You might also get away with taking the two front bolts out of the subframe which would allow it to drop down an inch or so to give you a little more clearance.
mngkaren
Nov 9, 2013 04:26 PM
Tilly Transport
Sep 6, 2013 01:56 PM
nbrabbit
Aug 10, 2013 08:12 PM
classic_coupe
Jul 29, 2013 08:58 PM
www.artracer.com
May 10, 2008 10:31 PM
