Audi 80 2.3 10v - Hesitation When Accelerating
Old Nov 21, 2006 | 09:47 PM
pedala250's Avatar
Default Audi 80 2.3 10v - Hesitation When Accelerating
Hello!
When i press the accelerator over 1/3rd, the engine hesitates like is got rich mixture. I changed the distributor cap because the old one was in a pretty bad shape. This improved the things a little bit. Next i removed the spark-plugs. No 1 & 4 cylinders were ok, but the rest were black, rich mixture black.
The fuel pump is pretty noisy, but i think is either the fuel distributor or the injectors...
Any idea?
P.S. Sorry for my bad english
Old Nov 22, 2006 | 12:13 AM
InExile's Avatar
Default RE: Audi 80 2.3 10v - Hesitation When Accelerating
change the plugs and if the plugs aer black there is a possibility of bad injectors
Old Nov 22, 2006 | 08:49 PM
pedala250's Avatar
I forgot to mention that the water temperature gauge isn't working. I checked the sensor (it's the 4 wire model) and no voltage is coming to it. I found an electric scheme and tomorow i'll try to find out why. Do you think the two problems are related?
Old Nov 23, 2006 | 01:41 AM
InExile's Avatar
it very well may be ... i think you have to mesure the rsistance at the sensor (ohms) to see if it is functional
Old Dec 7, 2006 | 06:30 PM
ecrabby's Avatar
sor the sensor is the 4pin one not the 2pin one on the top of the flange
robzz
Nov 5, 2014 05:28 PM
sokalkaz
Apr 28, 2012 12:25 PM
uncutworld
Oct 25, 2010 11:05 AM
ianjm
Feb 24, 2010 06:51 PM
tfvesquire
Apr 1, 2009 02:57 PM
