Clutch pedal stuck half down
Old Nov 1, 2005 | 10:19 PM
scottsellersunr's Avatar
Default Clutch pedal stuck half down
the clutch on my 4000CS is stuck HALFway down to the floor, like the rod is just in to far, but all adjustments, brackets, lines and fluid levels are good. What could cuase it to do that.. it cant just be pulled back out, its like its adjusted that far in and solid feeling like facotry set... just kinda gotten lower and lower... What the hell could cause this and what do i look for? Braking apeears to be perfect still so id think the cylinders are just fine. Everything looks normal all the way to the bell housing.
Old Nov 1, 2005 | 10:28 PM
TomRitt's Avatar
Default RE: Clutch pedal stuck half down
wrong forum but if its a hydraulic clutch the slave cyl is prolly done
Old Nov 2, 2005 | 07:53 PM
kakarot's Avatar
alos can be air in the system.
buellwinkle
B7 Models
9
Apr 28, 2017 06:13 PM
zero-o-matic
Mar 18, 2015 05:25 PM
dusted72
Nov 21, 2010 08:57 AM
rgall
Jun 17, 2008 01:45 PM
scottsellersunr
Nov 1, 2005 10:28 PM
