Please Help me
Old Nov 1, 2006 | 12:20 AM
1993Audi100S's Avatar
Default Please Help me
I own a 1993 Audi 100S with 2.8 6 cyl. The problem I am having is that it will not start. It will turn over till the battery goes dead but will not start. I have checked for spark and there isnt any. I have checked for fuel and everything seems to be in order there. I have also checked the timing belt and it turns when starter is cranked.
I have replaced the
Cam Position Sensor
The part before the coils I think its called an amplifier.
Still no spark I am Mechanically inclined but this is my first Audi.
I also tried pulling codes and none exist Comes up with 4444-No DTC's found
Please help so I dont have to send it to the stealership. Oh it also had a Remote start which I thought might be the problem so I removed it. Ask me any question I will do my best to answer. Thanks in advance for the help.
Old Nov 1, 2006 | 02:09 AM
InExile's Avatar
Default RE: Please Help me
is the timming actualy on time ?
Old Nov 1, 2006 | 06:30 AM
BadLuckAudi's Avatar
even if it was way off time it would still spark just at the wrong time... id check the ICM ignition control module
ORIGINAL: InExile
Old Nov 1, 2006 | 04:29 PM
InExile's Avatar
duh ... should have thought about the spark and timming before saying dumb things .... but the ICM is a good place to look
Old Nov 1, 2006 | 08:14 PM
Where would I find the ignition control Module at.
-Thanks
Old Nov 1, 2006 | 08:45 PM
I replaced the ICM its the part I meant when I said Amplifier. $300 Later. Any other Ideas
Thanks and sorry for my bad termonology.
Old Nov 2, 2006 | 02:38 AM
InExile's Avatar
Well , thre is a pssibility of bad grounds, having a bently manual and checking the wiring from the ICM and crank sensor to the "computer" would give you some insight maybe
Old Nov 2, 2006 | 09:19 AM
techbod's Avatar
yep could be the crank sensor or the VSS second picture to follow like where to find the sensors
[IMG]local://upfiles/12092/B64326643F734D77AFDA44A03ECE1711.jpg[/IMG]
Old Nov 2, 2006 | 09:20 AM
techbod's Avatar
opppswrong one[:@]
Old Nov 2, 2006 | 09:23 AM
techbod's Avatar
[IMG]local://upfiles/12092/919009EAF75242BDA1527E1EEA435B1F.jpg[/IMG]
