Hello, I have a 2001 tt. the car stalled out in my driveway and would not start, I loaded the parts cannon and changed fuel pump, fuel filter, checked fuel pressure and it was fine. I finally scanned it and it brought up a accelerator pedal code, I tried to hook my volt meter up to it and got less than .5v. did the same to the throttle body and same problem. does anybody have a wire diagram of the pedal and throttle body back to the ecu? when I try to crank the car it just turns over but when I spray some ether it will fire up and die almost instantly depending on how much gets sprayed.. any help is appreaciated!!
