Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
AEB nDBW/DBC tunes
Old Apr 29, 2011 | 10:02 AM
vtraudt's Avatar
Default AEB nDBW/DBC tunes
Stuck with the 98 nDBW/DBC 557P ECU, there are not many options for tunes.
Car came with uncommon "T.A.P. Stage 2 chip", currently running K03/K04 hybrid on stock fuel.
Yesterday, the GIAC PC16 ECU arrived. I want to try the file with 315cc/31lb injectors on 3 bar with the current turbo.
In the works is a K04+ hybrid (it was suggested to me to take the drop in K04-15 as the base, stick a K04-2x turbine in (machining of the hot side to fit) and the the K04-2x cold side. Ideally, would like to find a slightly larger compressor wheel that still fits into the K04-2x cover (RS6 wheel, other?).
With hopefully more flow compared to the K04-15, is the GIAC file/injectors running out of fuel? Limiting the potential of the K04max?
I had tried to find a 380cc file, but no one seems to make them for my nDBW.
But now found an (older) Unitronics 440cc file (and injectors) on a 557P ECU.
Is that too big for a "K04max" turbo described above?
Note: No, I don't want to go elim (on that car).
Lukeluk
Jun 5, 2011 07:35 AM
mosmoe
May 20, 2009 03:30 PM
aytheory
Aug 4, 2007 03:42 AM
buster1
May 22, 2007 09:30 PM
