Fuel Pressure Warning - A3 2.0 Fsi
Subscribe
Jan 2, 2013 | 05:04 AM
Hi all, if anyone has any hints on the following, it'd be sincerely appreciated!
Had the Check Engine light up on my A3 ('07 2.0 FSi) - vag-com is showing the following message below. Switched it off but same fault appeared the next day.
Any idea how serious this might be i.e. whether OK to drive for the next couple of days without too much issue for the engine? I assume most likely to be a new fuel pressure reg?
much thanks -
Ben
1 Fault Found:
004767 - Low-Pressure Fuel Pressure Regulation
P129F - 001 - Pressure too High - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 136520 km
Time Indication: 0
Date: 2012.12.02
Time: 10:58:32
Freeze Frame:
RPM: 879 /min
Load: 31.4 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 1.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Reply
Subscribe
