Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
How to track another computer in the same network?
Old Dec 25, 2010 | 06:41 AM
deslomec's Avatar
Default How to track another computer in the same network?
I would like to track another computer in the same LAN. I just want to see what is going on another computer. However the user working on the another computer should not know that someone is seeing what i am doing. Is there any way to track this?
Old Jan 18, 2011 | 12:25 PM
richellemedina's Avatar
in this case, you should try to add a trusted zone in firewall module for each computer you want to add ph34r.gif. follow these steps.
1.select the firewall to forward.
2.open the Network tab
3.select the network used in the areas
4.click the icon with a sign areas
5.select a team from the list either by name or IP - the Action menu, select confidence - click OK.
Old Feb 7, 2011 | 11:51 AM
brucewayne's Avatar
You can use software called a "network administrator to see it: "You can install in your system versions Professional Edition and the other end of the client, the advantage is that you can install the software from your system remotely, but you may need their own Password.
Old Feb 15, 2011 | 02:05 AM
discount ugg boots's Avatar
Touge
Apr 18, 2013 07:00 PM
Leppersmith
Apr 13, 2011 02:48 AM
gTT
Apr 23, 2007 01:45 AM
