Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Misfire on cylinder 4
Old Dec 8, 2007 | 03:46 PM
krystallos's Avatar
Default Misfire on cylinder 4
My car just started running very rough last night. I checked the trouble code and I it is showing a cylinder 4 misfire (P0304 I believe). I tried swapping the plug and coil pack with cylinder 1 and I have also checked the Ignition Control Module out, no change. Should my next step be checking/changing the fuel injector? If so, are there any good how to guides you all know about for replacing those? Any help is greatly appreciated.
Thanks
Old Dec 8, 2007 | 05:43 PM
krystallos's Avatar
Default RE: Misfire on cylinder 4
Well I found this great link for changing the fuel injectors
http://www.a4mods.com/index.php?page...injectors.html
so I swapped 4s with 1 but still have the misfire on 4. Where do I go from here? Wiring harness to CPs or fuel injectors? Any way to check these out without taking it in to get it done?
Thanks
Russ Heinrichs
Aug 18, 2021 12:39 PM
and b
Feb 10, 2014 11:52 AM
ThePizza
Jul 23, 2008 05:16 PM
ricky0323
Feb 29, 2008 01:35 PM
