Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Won't start after swapping engines
Old Nov 14, 2006 | 08:50 PM
Lfreese's Avatar
Default Won't start after swapping engines
I had an awesome reliable engine that ran in any situation. I found a car with a body and paint job that was much nicer and the car had less electronics in luxuries, so I switched engines because the engine in the nice looking car had much wear and tear. After swapping engines the car won't start after running the first time for about 3-5 mins. Just turns over and I get nothing. The only thing that happened after it ran the first time is the fuel tank was dropped and checked for loose contaminates. Is there a problem with compression or what. Where do I troubleshoot first to find out the problem. I heard from someone that oil pressure and fuel pressure has to be just right or you get nothing. This is what I am dealing with and how much info I have to go further on...
Please help!!!
Old Nov 18, 2006 | 03:23 PM
DGAFxxx's Avatar
Default RE: Won't start after swapping engines
is your engine getting fuel? Have you checked your fuel pressure? I would start there.
Also double check all electrical connections.
Do you have access to VagCom?
Old Nov 18, 2006 | 03:29 PM
techbod's Avatar
good advice there, is there any fuel in the tank?? do you have a spark at the plugs?? are all the air pipes on tight ( fuel/ air/ spark ) = a start
babdmb
B8 Models
Oct 13, 2013 10:55 AM
vtraudt
Aug 19, 2012 08:37 AM
DOC_DEPALMA
Mar 22, 2012 11:34 PM
Dynasty23
Apr 12, 2009 12:07 AM
S4sweeteeteeRS
Aug 16, 2005 06:27 PM
