Black 06 A4 and Bird Sh!t...help!
Old Sep 28, 2006 | 10:04 PM
Evan Matthews's Avatar
Default Black 06 A4 and Bird ****...help!
So I parked my 06 Brilliant Black A4 under a tree last night and got Shat on really big on my hood. I washed/ scraped off the chuncks and now I can't get the rest off. It's smooth! I tried Mothers Carnuba Cleaner wax 3 times, then I bought the Meguires Clay Bar and still nothing! Followed up with Meguires Cleaner wax and quess what... still there! Help....
Old Sep 29, 2006 | 03:48 AM
Default RE: Black 06 A4 and Bird ****...help!
Anyone...help please!
Old Sep 29, 2006 | 11:43 AM
TOGWT's Avatar
Bird Excrement:
(Or insect excrement like Gypsy moth, June bug, Honeybees, etc) contain highly acidic concentrates (uric acid (pH 3.0-4.5) which if left for any length of time the will cause the porous clear coat to occlude (a non-transparent ‘clouded’ area) or may cause etching (a depression in the paint or glass surfaces) Heat (vehicle paint temperature of 90oF+) creates a very aggressive reactivity of the acids that are present, which causes surface etching, so they should be removed without delay, at lower temperatures (40oF or less) there s no reactivity and therefore little or no etching.
No wax or polymer sealant can provide a permanent shield against acidic bird excrement (Collinite 845 Insulator Wax is probably the most durable Carnauba wax product) but this may only provide enough of a barrier to enable it to be removed quickly before causing too much damage to the paint film surface.
Birds use gravel to help digest their food so grit and sand are some of the major components, which can cause scratching. Insect honeydew (sometimes mistaken for tree resin) excreted by aphids or scale insects that infest the leaves and branches is also acidic. Residue should be removed (see below) as soon as possible as it could compromise the clear coat.
Take your time and be careful with its removal, these acids should be removed and/or neutralized as quickly as possible. Using an IPA (isopropyl alcohol) no ammonia based (ammonia acts as an acid accelerant) glass cleaner or a gel alcohol hand cleaner (Purell®) place a small amount on to a first aid gauze pad and apply to effected area this will help it stay in place during the necessary dwell time. The alcohol content, acts as a drying agent, which will extract the acid, then thoroughly flush with water to rinse away any grit or sand, etc or use detailers clay to encapsulate it, re-spray the area let it dwell for 2-3 minutes and wipe dry.
Avoid using a QD spray to flush residue, as they contain either carnauba wax or polymer sealants, which will seal the acid and not allow it to dissipate. Using an alkaline rinse of baking soda and water (to neutralize the acid) as soon as is practical is highly recommended, if the affected paintwork is not neutralized any remaining acid residue will be reactivated .If the paint or glass surface has been etched the surface can be levelled with a suitable polish (Zaino PC Fusion Dual Action Paint Cleanser and then apply a paint protection).
Old Sep 29, 2006 | 05:28 PM
Interesting info..gonna print for future reference. I went to a friend that details for Benz this morning and he was able to polish it out. Im gonna clay and do the 3 step meguires this weekend I think. There are alot of contaminates on the hood.
Parts4Euro.com
Nov 21, 2014 12:25 PM
IttyBittyTT
Jul 31, 2014 12:36 PM
Blown87camaro
Aug 13, 2007 07:36 PM
Amanda
Mar 11, 2005 04:30 AM
