How can I remove water spots from glass?
Old Mar 7, 2008 | 11:30 AM
cbg's Avatar
cbg
Default How can I remove water spots from glass?
I have water spots on my side mirrors and sunroof that I cannot stand and must get rid of. I have tried water/vinegar mixture and vinegar by itself. Are there any other remedies or products (that work....) that I can try?
Old Mar 8, 2008 | 07:06 AM
TOGWT's Avatar
Default RE: How can I remove water spots from glass?
There are two categories of water spot- [/i][/b]
[/i][/b]
a)[/b] Stage One Corrosion[/b] [: defined as a surface with light to moderate corrosion damage to the paint surface][/i]
b)[/b] Stage Two Corrosion[/b] [: definition when the dirt/corrosion deposits are no longer on the surface but have started to break down the molecular structure, leaving an etched or white haze on the surface after the stain has been removed, with moderate to serious paint damage] [/i]
[/b]
Removal of Water Spots - [/b]http://www.detailuniversity.com/forums/school-exterior-detailing/1862-removal-water-spots.html
Old Apr 22, 2008 | 02:02 AM
khooper's Avatar
[ol][*]Prepare a 50/50 mixture of water and white vinegar.[*]Soak a towel in the mixture and wipe down the area, making sure to keep it wet.[*]Drape the towel on the area for a few minutes so that it stays in contact with the surface.[*]Repeat the above process for severe spots.[*]For larger areas such as glass shower doors, pour the mixture into a plastic spray bottle.[*]Spray the mixture onto the glass, wiping frequently with the towel to help break down the limescale deposits.[*]Rinse and squeegie the area clean. Then buff dry with a clean cloth.[*]Remove faucet aerators and shower heads periodically and soak them in vinegar. A brush will help to loosen stubborn deposits.[/ol]___________________
Radiator Hose Accessories
Old May 12, 2008 | 02:44 PM
Quattro_1.8t's Avatar
Razor blade will get it usually if you put some window cleaner on the window and be easy with it
Old May 17, 2008 | 03:39 PM
Damy's Avatar
or check mequiars...they have anything
www.meguiars.com
WolfgangCarCare
Oct 22, 2014 10:17 AM
mrk3cobra
Aug 2, 2010 03:54 PM
gone postal
Jan 25, 2010 05:16 AM
jrward
Nov 26, 2008 05:53 PM
streetracer77
Aug 1, 2006 08:29 AM
