Wheel Paint
The following wheel renovation paints are available from Autogeek-[/i]
[/i]
1z einszett Silber Wheel Paint -[/i] can be used as a spot touch-up or whole wheels repaint. This paint is unusually user-friendly, it’s a fast-drying lacquer that matches the standard allow wheel paint use by Audi, BMW, Mercedes - Benz, Porsche, VW and most other European OEMs. One aerosol restores two complete wheels. They recommend topping their Silber Wheel Paint with Wurth High Gloss Clear to match the OEM gloss of new vehicles. Spray multiple thin coats of paint for the best coverage. - http://www.autogeekonline.net
Wurth European Blend Lacquers -[/i] used for all German (silver) painted wheels, This paint is unusually user-friendly, it’s a fast-drying lacquer that matches the standard allow wheel paint use by Audi, BMW, Mercedes - Benz, Porsche, VW and most other European OEMs. Wurth German Alloy Silver Wheel Lacquer can be effectively used for spot repairs or full wheel restoration - http://www.autogeekonline.net
Wurth Clean-Solve -[/i] a fast acting cleaner and solvent that will not leave a film residue of any kind. This cleaner will quickly remove wax, tar, gum, grease, paint overspray, adhesive, oil, and silicone. Clean-Solve will remove anything that might interfere with the bonding of the primer or paint to the wheel - http://www.autogeekonline.net
[/i]
1Z Einszett Spray Paint Primer “Haft-Grund”- [/i]a fast-drying, self-etching primer and filler with special bonding agent for application before painting, this lead- and cadmium-free primer is suitable for synthetic resin, acrylic and nitro combi paints. Apply on bare metal or filler only. Once you’ve cleaned the wheel thoroughly with Clean-Solve, apply this primer to prepare the surface for paint -http://www.autogeekonline.net
Wurth High Gloss Clear Lacquer - [/i]is formulated to match the original factory luster of your wheels. It is permanent lacquer paint, not a dressing. After you have repainted your wheels and allowed them to completely dry, spray Wurth High Gloss Clear Lacquer in light, sweeping strokes over the entire wheel face. Apply two or three coats for the best protection and the most attractive shine - http://www.autogeekonline.net
[/i]
[/i]
