Wolfgang Black Diamond Tire Gel
NON-SLING TIRE GEL
Wolfgang Black Diamond Tire Gel makes tires shine with an advanced polymer formula with UV blockers and ozone repellants. The penetrating tire protectant bonds to the rubber for long-lasting protection. Wolfgang Black Diamond Tire Gel is the finishing touch on a flawlessly detailed vehicle!
The latest formulation of Wolfgang Black Diamond Tire Gel takes advantage of cutting edge polymer technology to protect tires from rubber-aging contaminants, like dirt, ozone, and UV radiation. Wolfgang Black Diamond Tire Gel blocks out UV rays to prevent drying, aging, and fading.
Wolfgang Black Diamond Tire Gel is formulated to resist today's toughest environmental threat: ozone. Ground-level ozone is an air pollutant that is the main ingredient in smog. Ozone is destructive to many materials, including rubber. By regularly applying Wolfgang Black Diamond Tire Gel, your tires will stay soft, supple, and dark.
Wolfgang Black Diamond Tire Gel prolongs the life of your tires, conditioning and revitalizing them for up to two weeks, including a couple of washings! More than a tire dressing, Black Diamond Tire Gel keeps tire walls supple and hydrated to promote longevity.
Wolfgang Black Diamond Tire Gel penetrates beneath the surface to give your tires a long-lasting true glow that lasts weeks rather than days. The dark, satin finish will last through rain showers and car washes. One 16 ounce bottle of Wolfgang Black Diamond Tire Gel is equivalent to three or four 16 ounce bottles of spray-on tire dressing. Wolfgang Black Diamond Tire Gel is an excellent value!
Wolfgang Black Diamond Tire Gel consists of German super polymers, deep conditioning agents, and cutting edge protectants. This unique rubber protectant achieves spectacular results without relying on drying butyls, alcohols or petroleum distillates. No environmentally hazardous chemicals or additives go into Black Diamond Tire Gel. It is 100% biodegradable and safe on tires.
Maintain new tires and refresh older tires with high-bonding, non-slinging Wolfgang Black Diamond Tire Gel. It delivers the clean, satin finish prized for show cars and collectibles plus the protection needed for daily drivers.
Check out this video -->
Directions:
1. Work out of direct sunlight. Clean tires first with Wolfgang Tire & Wheel Cleaner and allow them to dry.
2. Squeeze a thin bead of Wolfgang Black Diamond Tire Gel across your foam applicator or tire swipe. Less is more!
3. Apply a thin coat across the surface of your tire—just enough to moisten the surface is all you need. It will absorb and no sling-off will occur.
4. Control the level of shine according to your preference. One light application of Black Diamond gives the optimal amount of shine for a well-dressed look that suits most cars. For less gloss, follow application of gel by wiping down with a clean dry towel. For a higher level of sheen, wait ten minutes then apply another coat. Repeat until satisfactory results are achieved.
5. It's best to allow 30 minutes for the gel to cure. You will enjoy a beautiful finish on your tires that lasts for weeks.
Tech notes: Proper application is important to maximize the effectiveness of this product. The viscosity of Wolfgang Black Diamond Tire Gel allows the product to be applied neatly and evenly, sit and penetrate the tire walls, and prevents messy sling-off. For best results, carefully apply one thin, even layer, swiped over the surface. This gives a handsome, well-dressed gloss that compliments most vehicles. If you prefer a heavier, glossier shine, wait ten minutes and reapply. For less shine, follow the initial application by immediately wiping tire with a clean cloth. Wipe off excess tire gel around raised letters and between the wheels' edges and tires where the gel can puddle. Allow the gel to cure for 30 minutes before driving.
Viper966
05-17-2010 11:52 PM
cmfering
15
10-30-2008 10:19 PM
stryker
01-27-2008 01:16 PM
