2009 a4 convertible top
Old Mar 17, 2023 | 03:23 PM
CandleBread's Avatar
Default 2009 a4 convertible top
Hi all, I’ve been having a problem with my 2009 a4 convertible top. When I pull back on the switch in the center console to lower the top, the top will pop out of the latch at the top of the windscreen and then refuse to move. It stays perhaps an inch from the latch here. Using the switch becomes useless at this point and you have to get out and manually lower the top or place it back in the latch using the convertible top key from the fuse box. Has anyone had this problem/solution? Thanks in advance.
Old May 25, 2023 | 02:04 PM
dankoch01's Avatar
Default Any resolutions?
Hello,
Wondering if you reached any resolution on your convertible top issue? I see lots of posts with people having an issue but no obvious fix.
Thx,
Dan
Old Dec 27, 2023 | 01:06 PM
Falconkeeper's Avatar
I found the factory sequence and location of microswitches on Volkspage.net. Look under Technik. I downloaded this onto my audi pen flashdrive, so now it travels with me.
Old Feb 18, 2024 | 06:57 AM
davideidson's Avatar
There are a number of potential causes for the problem you're having with your Audi top, and fixing convertible top issues may occasionally be difficult. But here are a few typical explanations which according to my perspective you are facing.
Level of Hydraulic Fluid, Limit switches and sensors, latching mechanism for a hydraulic pump motor,Voltage of Battery, Top Module Convertible Reset.
Seeking expert assistance is a better option for you than listening to advice from non professionals.
Firefighter
May 30, 2016 10:36 AM
LBrown7
Oct 18, 2014 07:41 PM
JF1957
Feb 27, 2013 01:01 PM
IITravel
Sep 23, 2008 08:45 AM
torres
Oct 4, 2007 07:58 AM
