aftermarket head unit resets itself with power off
Old Mar 24, 2008 | 11:08 PM
EOD5's Avatar
Default aftermarket head unit resets itself with power off
oh my do i hate wires..... i have installed dozens of head units before but this is just driving me nuts
i put an aftermarket pioneer 2000mp in the car last week and wired everything the way it should be...although i am having a problem.
when i turn the car on the headunit doesnt go on with it, i have to manually turn it on, and then it forgot where the last settings were at etc etc...works 100% fine until i have to turn the car off and back on
i have all the wires hooked up properly, accessory is going to accessory and constant to constant...but still it is losing power and not keeping that small trickle of "save" energy when the car goes off
anyone have a clue why this happens? is this a common problem with these A4s, because like i said, ive done tons of installs and never had a problem like this before.
thanks!
Old Apr 23, 2008 | 10:26 AM
rgrizzard's Avatar
Default RE: aftermarket head unit resets itself with power off
I would contact Pioneer tech support. The units typically have batteries as well. That could be the problem also.
Old May 26, 2008 | 07:00 PM
A4 Effort's Avatar
Since this is a fairly old post, i'll assume you got your problem fixed. However, on the slight off-chance that you haven't, try swaping the accessory and battery wires with one another. I had the same problem when i installed my kenwood deck, and discovered that if i swapped those two wires, everything was fine.
MilliesDad
Jan 31, 2013 04:51 AM
technohippy
Dec 20, 2007 10:57 AM
portny33
Aug 16, 2007 10:21 PM
duckman
Feb 10, 2007 03:46 PM
brent07
Mar 7, 2006 01:24 PM
