AudiForums.com
-   Electronics (https://www.audiforums.com/forum/electronics-30/)
-   -   Help! Dipped H7 headlight not working but full beam working???? (https://www.audiforums.com/forum/electronics-30/help-dipped-h7-headlight-not-working-but-full-beam-working-178741/)
azzy28 Jan 26, 2012 07:29 AM
Hi All,
I have a issue, I have a 2005 Audi a3 2.0tdi 140, I was just driving and my left passenger H7 dipped headlight went out and came up with a fault on the dash, however from the same bulb the full beam is working :confused: I have changed the bulb and the problem is the same. The driver side headlight is working fine.
I have had 100w H7 bulbs fitted there was a while but took them off and also i did try a HID kit of the left headlight afew times which worked but fitted it in so that may have blown something.
Any ideas/suggestions would be much appreciated :)
Regards
ImTheDevil Jan 28, 2012 10:30 AM
It's much more likely that the 100W bulbs either melted the harnesses or blew the fuse (did you check the fuse?). HID systems only draw 35w (less than the 55w of a normal halogen bulb). Check your fuse, and if it's OK, you may have blown the low-beam filament in the bulb. Don't ever try and run bulbs that draw that much current. You're asking for a fire.
azzy28 Jan 29, 2012 11:03 AM
I have checked the fuse and that's fine. I have changed the bulb but still no luck. What would you advise to check now?
