Help! Dipped H7 headlight not working but full beam working????
Old Jan 26, 2012 | 07:29 AM
azzy28's Avatar
Default Help! Dipped H7 headlight not working but full beam working????
Hi All,
I have a issue, I have a 2005 Audi a3 2.0tdi 140, I was just driving and my left passenger H7 dipped headlight went out and came up with a fault on the dash, however from the same bulb the full beam is working I have changed the bulb and the problem is the same. The driver side headlight is working fine.
I have had 100w H7 bulbs fitted there was a while but took them off and also i did try a HID kit of the left headlight afew times which worked but fitted it in so that may have blown something.
Any ideas/suggestions would be much appreciated
Regards
Old Jan 28, 2012 | 10:30 AM
ImTheDevil's Avatar
It's much more likely that the 100W bulbs either melted the harnesses or blew the fuse (did you check the fuse?). HID systems only draw 35w (less than the 55w of a normal halogen bulb). Check your fuse, and if it's OK, you may have blown the low-beam filament in the bulb. Don't ever try and run bulbs that draw that much current. You're asking for a fire.
Old Jan 29, 2012 | 11:03 AM
azzy28's Avatar
I have checked the fuse and that's fine. I have changed the bulb but still no luck. What would you advise to check now?
cymorg
Jan 12, 2014 12:30 PM
Madmick
B7 Models
Dec 2, 2012 12:18 PM
padfitz
Aug 31, 2011 04:39 PM
OwDeeAy3
Oct 31, 2010 04:14 PM
moonstruck
Feb 20, 2008 11:09 PM
