Ignition system electrical issue (new ignition switch) (2002 A6, C5, AVK)
Quick Backstory
I own a 2002 A6 (C5) with the AVK engine. A week ago I went to a charity car wash and some local members of the military wash my car. When getting back into it, the car wouldn't start; however, the electronics were all on even when I removed the key. After fiddling with it there without any of my tools, I decided to just have the car towed back to the house to work on.
Diagnostics/Repair Attempts
After running an auto-scan on the car, I found the following code that I think is the culprit:
I checked out the 00849 Code page on the Ross-Tech Wiki as well as these forums and everything that I read about this code mentioned to replace the ignition switch. With as cheap as it was, I went ahead and did that. That page refers only to the "Unknown Switch Condition" error however, and I've got an "Open or Short to Ground" instead. I figured some water from the car wash was just causing an issue so I tried to clean/dry up the area around the starter to see if that was it to no avail.
While I can twist wrenches, my electronics/electrical skills leave a lot to be desired. What I've done so far is checked the resistance at the ignition switch harness for the recepticle that mates with Terminal 50 of the ignition switch (after reading another post on this forum that mentioned this) and read ~70Ω resistance which I further believe is indicative of the open/short. When the ignition switch is connected, the instrucment cluster lights up completely, but when putting the key into the ignition the spring in the ignition switch doesn't do anything. I think that the "S-contact"/"Terminal S" refers to the switch in some way, but I'm not sure exactly what it means.
At the bottom of this post, I've added my most recent (truncated) VCDS scan after I cleared the codes as well as the advanced measuring blocks for the Immobilizer because I thought at first that it might have been an issue; on a previous scan I didn't have the key in the ignition and the battery voltage was low which was causing the Immobilizer light on the dash to blink, but with a charged battery and the key in the ignition it went away. The codes for the airbag and steering wheel are just because I still have all of that disconnected.
Would someone be able to help me with what I should be doing to track down where the issue is. As I said before, I am fairly inept with using my multimeter, so explicit instructions when it comes to where/what to test would be great! I've got access to my digital Bentley Manual with all of the wiring diagrams and I have my VCDS so I can retrieve any additional information from there as well if it would be helpful. Thanks a ton!
VCDS Scan Output
VCDS Immobilizer Blocks
This is from 17 Instruments, Groups 022, 023, and 024.
Code:
00849 - S-contact at Ignition/Starter Switch (D)
31-00 - Open or Short to Ground
VCDS Scan Output
Code:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
VIN: WAULT64B02N------
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016752
Shop #: WSC 02325 785 00200
VCID: 3620E72840173FF24A-5184
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 1728
Coding: 06497
Shop #: WSC 00000
VCID: 26003768C0B74F72FA-5184
1 Fault Found:
00285 - ABS Wheel Speed Sensor; Front Right (G45)
30-00 - Open or Short to Plus
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00110
Shop #: WSC 02325
VCID: 5CF45580CD7BC5A29C-2596
2 Faults Found:
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4B0 959 655 N
Component: Airbag 8.4E 4001
Coding: 0000307
VCID: 3B36F61C7B35E29AB5-5184
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01002
Shop #: WSC 02325
VCID: 2F2ED24CEC4D0E3A09-523C
1 Fault Found:
01426 - Controls in Steering Wheel (E221)
49-00 - No Communications
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 N
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 02262
Shop #: WSC 65535
VCID: 312AD434F97918CA1F-5184
WAULT64B02N------ AUZ7Z0A-------
1 Fault Found:
End----------(Elapsed Time: 06:02, VBatt start/end: 12.8V/12.8V)-----------
Code:
Group 022: Engine Start Permitted: 0 ECU Responding: 1 Key Condition OK: 1 Number of adapted keys: 3 Group 023: Variable Code Matched: 1 Transponder Status: 1 Fixed Code Authorized: 1 Immobilizer Status: 6 Group 024: Cluster Lock Time: 0 ECU Lock TIme: 0 Not used 0 Transponder Lock Time: 0
bejum95954
Aug 2, 2022 04:39 AM
jpf566
May 2, 2013 05:21 PM
