Installing sub on stock amp???
Old Jun 28, 2007 | 03:39 PM
c346123's Avatar
Default Installing sub on stock amp???
I have a 98 A4 with a non bose stereo and am wondering how I could wire up a 10" sub to the stock amp on the rear speaker,is it possible or do I need to get another amp and connect that to the stock amp,how would i do that . any input will be helpful thanks.
Old Jun 28, 2007 | 05:39 PM
a12gaugehug's Avatar
Default RE: Installing sub on stock amp???
i would not recommend hooking up a sub to your stock amp, the stock amps are pretty low power and are meant for door speakers. if you did end up hookin up the sub to it you would probable just fry the amp anyways by drawing too much power at too low of an impedance
Old Jul 18, 2007 | 01:24 PM
votblindub's Avatar
simple answer: no
complex answer: stock amps are made to handle those tiny *** subs they put in. theyre only like 4-5 inches in diameter and dont take much power. the stock amp doesnt produce much power either, plus its tuned to use those speakers in the stock enclosure. if u start changing stuff, but not all of it, itll end up sounding off and just plain weird. i dont like the factory setup for its crossovers(if any at all), the stock EQ doesnt do much and its very rough. you may also blow that amp due to different impedance of the aftermarket sub vs the stock subs.
luxuryimports1
Oct 7, 2009 04:40 PM
Ringin'It
Feb 3, 2009 02:38 PM
MK1audiTT
Apr 21, 2008 05:26 PM
A4 the Quattro
Nov 10, 2007 10:20 PM
Big Blue S90
Nov 20, 2006 03:48 PM
