Interior Lights Failure
Old Sep 13, 2015 | 11:47 AM
Bonjour75's Avatar
Default Interior Lights Failure
Hi,
I have a 2008 Audi A4 2.0 Quattro and recently installed an after market blue tooth stero. While in process of locating where to put the microphone for this unit, I had the interior light panel near the sunroom pulled down about an inch and a half to 2 inches from the ceiling trying to see where this microphone might go. The Map light began to flicker and then I lost all the interior lights. I have removed the fuse cover panel and checked all fuses and removed the entire panel where map lights are located and everything seems to be plugged in. Using multimeter to check and make sure there was current going to those lights and there does not seem to be any and did a continuity check and that was good also, any advice ?
hoovdiddy
Jul 5, 2017 10:19 AM
papisway
May 15, 2014 08:32 PM
nize
Jun 21, 2013 01:16 PM
Jeffreys
Feb 15, 2012 06:30 PM
