Need a replacement radio (with USB) for my '04 A4
The previous owner of my car (2004 A4 Quattro with the symphony cassette/6 disc changer) damaged the lcd screen on the radio to where it's mostly blotched out. I'm looking for something that I can replace the stock radio with something with a USB port to listen to the music on my phone/internet radio, as well as hopefully keeping the 6 disc changer, although that is not a hugely important part. Mostly I just want to be able to read the screen and use usb devices.
Would anyone be kind enough to point me towards a product like this? I have used google but found a confusing list of aftermarket systems, that i'm not sure fit my car/needs Thanks! and it feels good to be in the Audi fam ;) |
2 Attachment(s)
I did all the stereo work in my 04 A4..
Had the stock Symphony II (iirc) I must warn you, if you're debating on tackling this yourself, it's quite the headache at first but definitely worth the time & effort. First, I suggest you start with an: A4 B6 Single Din Dash Kit Next step is deciding on the aftermarket cd player you'd like. I recommend Pioneer for a budget install. Just make sure the CD player has an AUX input on the face of it. --> I'd recommend this one for you <-- It has the 3 High Voltage Preouts (RCA outputs) that you need to install a sub in your car. Any other questions, just ask. Here's my dash: Eclipse AVN 6600 |
thank you friend! once i collect enough money your information shall be put to use. :)
Hijack.....
ive installed 100's of radios in my time but never on an audi, is this jsut as simple as a plug and play like everyother car or does it need to go through the VAG system? |
It "should" be plug and play as long as you get the correct wiring harness...
No need to mess with the VAG. Research the Audi and find out if a Symphony/Bose amp is in the back (Normally behind trim in trunk; above rear passenger wheel well... at least that's where my Symphony II amp is) I hope this steers you in the right direction. |
