speaker size for 97
i've got a 1998, and i replaced all the speakers in mine.
all the speakers are a bit of a pain to be honest.
firstly you will need to get the correct mounting brackets as the original speakers have an in-built bracket.
secondly the rear left has a built in amp (for the non bose system anyway), and basically both the rear speakers are fed from this. also you will need to remove the parcel shelf for access!
so you will need to cut the wires at the harness under the parcel shelf. find out which are pos/neg left/right channel and distribute accordingly.
the size of the speakers for the parcel shelf will be 16.5 cm and the bracket you will need is a "Autoleads SAK-1105".
i got all my stuff from www.lowcostcaraudio.co.uk, but i'm in the UK, seemed the cheapest place for the brackets / speakers etc.
hope that doesn't put you off!
