FOR SALE=coils,plugs,clutch,MAF,o2,filters,gaskets,ICM
Hi guys and gals,
I am very excited to have an opportunity to extend my connections with ASAP Auto Parts (Long Beach, CA) to everyone here. I am great friends with the owner and he gets great OEM and aftermarket parts for our cars.
Best of all ASAP Auto parts come with 1 year warranty!(even electrical parts!)
There is too much to list so please don't hesitate to send me a PM.(about any car!!!)
-------------B5 S4-----------------------
Fuel filter (bosch) .....................$12.00
Fuel Pump................................$260.00
Fuel Press Reg..........................$42.50
Front Pads (ceramic)..................$50.00
" "(semi met.).............$40.00
Rear Pads (ceramic)...................$45.00
" "(semi met.)..............$35.00
Front Rotors (Brembo)................$79.00
" "(economic)............$49.00
Rear Rotors (economic)...............$39.00
Clutch kit..................................$425.00
Water Pump w/ gasket................$65.00
Auxiliary Water pump.................$90.00
MAF (Bosch/new).......................$170.00
Front O2 sensor (Bosch w/ oem
connector).......$105.00
Rear O2 sensor (Bosch w oem
connector)
LH................................$100.00
RH................................$120.00
Valve Cover Gasket Set (valve
cover/spark plug seal)..........$22.00 per side
...and much more!!! send me a PM!
------------------- B5 A4, 1.8t ----------------------------
Fuel Pump..............................$150.00
Fuel press. reg.(Bosch)............$45.00
Fuel Filter(Bosch)....................$12.00
Front Pads (ceramic)...............$50.00
" "(semi met.)..........$45.00
Rear Pads (ceramic)...............$45.00
" "(semi met.)..........$40.00
Front Rotors (Brembo)............$69.00
" "(economic)........$49.00
Rear Rotors (Brembo).............$59.00
" "(economic).........$39.00
Water Pump w/ gasket............$49.00
Water Pump asy w/ Thermo-
stat housing).........$69.00
Thermostat w/ gasket.............$18.00
Wheel Bearing Kit (***)..........$49.00
Alternator (Bosch, reman.)......$220-$250...(please specify amperage and pulley grooves)
MAF Sensor
[AEB] (Bosch, new)........$170.00
[ATW] (Bosch, new).......$140.00
[ATW] (Bosch, reman)....$90.00 w/49.99 core charge(refundable)
O2 Sensor (Front w/ OE connector)
[AEB] -Bosch....................$109.95
[AEB] -economic.............$95.00
[ATW] -Bosch....................$139.95
[ATW] -economic.............$125.00
O2 Sensor (Rear w/ OE connector)
[AEB] -Bosch....................$99.00
[ATW] -Bosch....................$104.95
Ignition Coils
[AEB] -Beru.....................$53.95
[ATW] -Beru.....................$40.99
ICM
[ATW] -Bosch, new...........$139.00
[ATW] -Huco....................$99.00
Spark Plugs
-Ngk laser platinum PFR6Q.....$44.95 (set of 4)
Manuel Clutch asy.
4cyl.................................$320.00
6cyl.................................$240.00
....lots more available!!!! PM me!!!!!!!!
connector)
MAF Sensor
Ignition Coils
ICM
Spark Plugs
Manuel Clutch asy.
JETSPEED333
Feb 1, 2012 03:15 AM
