How do I thin OEM touch up paint?
I have successfully applied the base coat to my A4 paint. I use Ultrabrush applicators dipped directly into the OEM paint pen (after removing the entire cap assembly). The base color flows nicely leaving a smooth, even surface.
My prior experience with the top clear coat, however, is that it is thick and does not flow into the area that I'm trying to fill. I used the same type product that came with my VW touch up paint.
What can I use to thin the paint?
