02 A6 2.7T smoke - Turbo Failure?
Old Feb 2, 2010 | 10:35 PM
jiufeng@gmail.com's Avatar
Default 02 A6 2.7T smoke - Turbo Failure?
My 02' A6 2.7T smoked badly from both exhaust pipes last week. A local mechanist found some oil in intercooler so he said it was a turbo failure. Is that true? If this is the problem, is it possible for me to DIY?
Old Feb 24, 2010 | 02:26 PM
R.A.I. Motorsport's Avatar
Former Sponsor
it may not be the turbo's it is possible a check valve is stuck. I cant remember which valve it is off hand, but if the car doesn't do it all the time i would think twice before replacing the turbos.
Old Feb 24, 2010 | 08:41 PM
Darkprodo's Avatar
theres the breather assembly in the back of the motor... its like 300.00.
moisture gets inside and when the cold weather comes tends to freeze and bind up the valve inside.
I doubt theres a DIY for replacing turbos..... cause the whole motor has to come out. And taking the motor out..... is the easy part.
i have special wrenches i have cut and made for this job..... and i'll never look forward to doing it
Old Jan 23, 2011 | 01:15 PM
carbonhornet's Avatar
I would love to know more about this breather assembly and where it is located because my allroad has the same symptoms every now and then the car will smoke and only during very cold weather. if you can give me links to the part that would be appreciated thanks for the info.
liverman12
Oct 10, 2012 12:55 AM
stimm32
May 16, 2011 06:56 PM
jdmaine
Apr 23, 2011 06:58 PM
ahwest
Mar 25, 2008 04:25 PM
audiboy1618
Aug 14, 2004 10:55 PM
