04 a8l won't turn over
Old Dec 7, 2006 | 09:39 PM
braidy's Avatar
Default 04 a8l won't turn over
All lights and functions work, but car will not turn over when you try to start it.
Please help!
Old Dec 7, 2006 | 10:37 PM
tractioncontrol's Avatar
Default RE: 04 a8l won't turn over
If there is no clicking sound at all it is most likely the starter.
Old Dec 8, 2006 | 10:40 AM
rayveedub's Avatar
still could be the battery, most newer audi have huge batteries that are heavily used by the car, the A8 i would imagine even more. When my A4 battery started going up i thought it was the starter because the battery passed testing. I threw in another battery just to be sure and it was the battery. If it dosent have enough cca's it wont do a thing at the starter.
Old Dec 8, 2006 | 08:19 PM
braidy's Avatar
The mechanic said that he tested the battery and that if it is below 10.6 volts it won't start. He said that our battery tested above that, so it is not the battery. Any other thoughts, suggestions, etc., would be greatly appreciated.
Thanks!
Old Dec 8, 2006 | 10:52 PM
AWDaholic's Avatar
Senior Administrator
Put yer foot on the brake and move the shifter to drive and back to park. Then try it <<shruggs>>, it worked with an exGF's B-M-Trouble-U, once...
Old Dec 9, 2006 | 09:46 PM
dankhound's Avatar
You cant really test the battery the old school way because there is a battery manager module that can cause the battery tester to read incorrectly. Check for faults. Many times there will be a fault for engine mechanical block during starting or something like that. That fault is thrown when the access start control module tells the starter to start but the engine doesnt turn. I would also check the battery. It should be higher than 60% in the mmi. It should also be way more than 10v. More like 12.5.
Old Dec 10, 2006 | 03:28 PM
rayveedub's Avatar
thats completly correct advice above, a easy way is to plug in another battery from somewhere else with similiar cca's and try it then. also you should listen to awdholic, i didnt think about it but the shift neutral safety switch could be faulty. maybe you can try to start it in nuetral.
Old Dec 10, 2006 | 03:35 PM
techbod's Avatar
I guess its an automatic/tip thingy? starter inhibitor
Old Dec 15, 2006 | 12:37 AM
braidy's Avatar
the problem ended up being a loose starter strap. ? thanks for all the responses!
kimburrly
Audi Q7
Apr 17, 2011 05:47 PM
Ky allroad
Sep 1, 2009 06:58 AM
grapejuice
Jan 9, 2006 09:03 PM
skidplatexa4
Sep 15, 2005 12:33 PM
paliracer
Feb 21, 2005 03:15 PM
