17125 - Torque Converter Clutch P0741 - 003 - Stuck OFF / No Power being
Hi,
I have a A6 2003 (4B). I have been getting the following error codes for some time.
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 4B0 927 156 FF
Component: AG5 01V 3.0l5V USA 0910
Coding: 0001002
Shop #: WSC 02325 785 00200
VCID: 70E5CE1960B8329
1 Fault Found:
P0741 - 003 - Stuck OFF / No Power being transferred - MIL ON
Freeze Frame:
RPM: 2240 /min
RPM: 1952 /min
RPM: 1952 /min
(no units): 1.0
Torque: 152.0 Nm
Temperature: 68.0°C
T.B. Angle: 26.4°
(no units): 4.0
My Garage guys keep telling me I need to go for a Gearbox overhaul with a budget of over $2K. Please could some one help with information on the topic. I use VCDS for running the scan. I am currently stuck with no knowledge of how to run indepth scan to troubleshoot this problem.
thanks
K
Coding: 0001002
1 Fault Found:
Freeze Frame:
RPM: 2240 /min
RPM: 1952 /min
RPM: 1952 /min
(no units): 1.0
Torque: 152.0 Nm
Temperature: 68.0°C
T.B. Angle: 26.4°
(no units): 4.0
thanks
K
You need a new torque converter.I have an c5 a6 got same code.tranny wont go into overdrive. Mine is in shop now getting fixed.Im getting my timing belt and tc and flashed for $4600.I still got 21mpg.I called Audi dealer they wanted $3000 for tc.I got JA Autowerks doing mine.If you are in NJ give John a call tell him Jimi sent ya he will take care of you! He paid for my rental car from Enterprise 2012 sentra cant complain. If they dont know Audi dont let them work on it!!! When you drive your car look at your rpms at 55 your rpms will not drop below2200-2000.Again if your mechanics are not familiar with Audi's dont let them work on it! It will cost you more if they do!!!!!
Hi Gman 56
Thanks for the tip and reply. I live in the desert (UAE). Guess the guys here want to fleece where they can. My 4B A6 3.0 is a US model and dependent on repair shops than the dealers. guys that is a good thing. You are lucky and getting 21 mpg. I dont get any where close to 15.
Let me call them up and find out if they would ship one out here. May be that would save me a lot of pain.
K
K
Wow K , are you military? I use 93 octane gas.21 mpg
Highway around town 18 mpg.with torque converter locked off no overdrive thats why bad mpg. I hope you can get tc.I cant afford dealer price either.my Audi tech worked for Audi opened his own shop.not many people use the dealer for repairs unless under warranty.Good luck and have a good day!
LEVEL10TRANSMISSION
Jun 2, 2011 01:40 AM
LEVEL10TRANSMISSION
Mar 21, 2011 02:34 PM
LEVEL10TRANSMISSION
Mar 21, 2011 02:27 PM
LEVEL10TRANSMISSION
Mar 21, 2011 02:14 PM
mas363
Oct 5, 2010 11:48 PM
