1993 Audi 90S Engine removal instructions?
Old Dec 19, 2008 | 12:43 PM
kplords's Avatar
Default 1993 Audi 90S Engine removal instructions?
Hello everyone, my name is Kevin, and I'm new here...and I've just purchased my first Audi, a 93 90S, 2.8l V6. It came complete with a dead engine,...But with the car I got a '95 2.8l V6 engine with only 9k miles on it, and I need to do a swap. I cannot find any repair manuals for the car, so I thought I would check in with the tech forums in search of a thread or some help with step by step from the pros here at AudiForums. Does anyone have a link to this information online? Or any suggestions of where to find this information...Or do I need to order the $100 Bentley CD? Thank you in advance! Kevin
***addition***
Dead as in overheated and it has at least 2 cyls that are puking water out of while cranking over with spark plugs out, and it has 96,000 miles on it. Supposedly overheated due to failing heater core. But this has not been confirmed. Just what the previous owner has said. As it also came with a '95 2.8l v6 with 9k, this had been in a front end crash and has a broken oil pan, and timing belt gears are also broken. Block and head seem to be okay. Was just planning on swapping the good parts for the bad onto the 95 9k motor and doing the eng. swap. Maybe I should should get a gasket kit and swap the heads and save the 9k motor.???
DouginDenver
Dec 28, 2011 12:25 PM
alexandyr
Oct 10, 2010 08:26 AM
harveg
Oct 6, 2010 11:59 AM
coolvirus
Jul 18, 2006 08:38 PM
dhdallas
Aug 30, 2005 06:06 PM
