2006 A4 Crank but No Start
This is my first time here looking for some knowledgeable assistance regarding my dilemma. I have a 2006 Audi A4 2.0 that won't start now after replacing (4) ignition coil packs and spark plugs with OEM parts. The reason for replacement was because I was driving the vechicle and all of a sudden it started to stutter and shake and the CEL started to flash rapidly. Did some research and concluded it was a bad coil pack causing a misfire. Also replaced the battery as well and now it cranks but won't start. Conducted a spark test on the coils and spark plugs and didn't achieve any indication of spark. Checked all fuses to be in good condition. If anyone could please help shed some light on this it would be highly appreciated. Thanks in advance. I ran a Vag-Com diagnostics on it and these were the only fault codes present:
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUAF78E56A157230
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0070
Revision: --H10--- Serial number:
Coding: 0104010A02070120
Shop #: WSC 05140 444 94213
VCID: 2B5F2055F39E
No fault code found.
Readiness: 0110 0101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 8E3 910 155 C HW: 01J 927 156 HT
Component: V30 01J 2.0TFSI USA 0010
Revision: 00000009 Serial number: 00000001187324
Coding: 0000001
Shop #: WSC 04940 001 00001
VCID: 2855DF59E268
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 D HW: 8E0 614 517 AK
Component: ESP8 front H05 0120
Revision: 00000000 Serial number: 00000000000000
Coding: 0004525
Shop #: WSC 06335 000 00000
VCID: 2855DF59E268
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0202
Hex Value: 0x0024
Hex Value: 0x0187
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2832
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDE3493610
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0504
Coding: 00003
Shop #: WSC 06335
VCID: 3B7F101503FE
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H11 3540
Revision: 91H1135 Serial number: 0036N0016RN3
Coding: 0032607
VCID: 3C7D130906F0
Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 02021
Shop #: WSC 06335
VCID: 418362FD6112
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H12 0110
Coding: 0022261
Shop #: WSC 05811 444 999999
VCID: 2E592941C08C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3332
Coding: 11836
Shop #: WSC 06335
VCID: 840D2BE9BE80
Part No: 8E1959801G
Component: Tőrsteuer.FS BRM 0506
Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0205
Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0606
4 Faults Found:
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0460
Coding: 01005
Shop #: WSC 70656
VCID: 2C5D2349F690
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
36-10 - Open Circuit - Intermittent
End ---------------------------------------------------------------------
69 75 76 77
VCID: 2B5F2055F39E
Coding: 0000001
VCID: 2855DF59E268
Coding: 0004525
VCID: 2855DF59E268
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0202
Hex Value: 0x0024
Hex Value: 0x0187
Hex Value: 0x0000
Coding: 00000
Shop #: WSC 00000
VCID: 6CDDE3493610
1 Fault Found:
Coding: 00003
Shop #: WSC 06335
VCID: 3B7F101503FE
Coding: 0032607
VCID: 3C7D130906F0
Coding: 02021
Shop #: WSC 06335
VCID: 418362FD6112
Coding: 0022261
VCID: 2E592941C08C
No Faults Found
Coding: 11836
Shop #: WSC 06335
VCID: 840D2BE9BE80
Part No: 8E1959801G
Part No: 8E1959802E
Part No: 8E0959801E
Part No: 8E0959802E
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 01005
Shop #: WSC 70656
VCID: 2C5D2349F690
1 Fault Found:
