2008 Audi Q7 4.2 TDI S Line ECU
Old Jun 13, 2018 | 03:59 PM
grahamljc11's Avatar
Default 2008 Audi Q7 4.2 TDI S Line ECU
Hi, Ive just purchased a used 2008 Audi Q7 4.2 TDI, its a none runner due to water ingress into the fuse box. The seller has had both ECUs repaired, but they are currently both off the car and I'm unsure which one is number 1 and number two ? I'm also unsure which ECU goes where, ie left/right of the car. I've done some research and which says number one ECU is the Master and number two ECU is the Slave, my research says all files are identical except for eeproms 95320 ? which means absolutely nothing to me ??? Does it matter which side of the car the ECU are installed ? Would really appreciate any advice, thank you, regards Graham.
stonevs
Oct 24, 2015 09:54 AM
lakmun
Feb 28, 2014 11:16 AM
marsh369
Aug 29, 2011 09:14 AM
torres
May 9, 2007 04:42 PM
S_R_N83
Jan 2, 2007 12:23 AM
