2009 A8L D3 No Crank or Start
Old Aug 22, 2021 | 04:11 PM
JohnnyT13's Avatar
Default 2009 A8L D3 No Crank or Start
I have a 2009 Audi A8L D3 that will not crank or start.
I owned and drove the car for 1 month without issues. The problem began with errors "ACC not available" and "Parking break malfunction!" and I would have difficulty starting the car. Repeatedly trying to start the car would allow the car to start and run. I noticed the battery would die very quickly while running and inspecting codes, and a jump start would start the car without issue. Battery tested bad, so I replaced the battery. It ran without issue for 1 week after replacing the battery.
Suddenly, the errors returned and I have been unable to start the car. It also gave an additional error "Engage N or P to start engine" (I've tried both N and P, with no crank or start).
OBDeleven will not connect for some reason (works great on my newer Audi), but Carly with a cheap OBD adapter pulls and resets codes just fine. Reset codes with Carly, and attempted to start car. Then re-ran Carly diagnostics. PDF from Carly is attached.
Ideas on what to check next are very much appreciated! Thank you so much in advance for your help!!
File Type: pdf
Tracy L Polk
Jun 22, 2021 06:39 AM
willie7182
Dec 15, 2010 11:25 PM
Pat W
Sep 19, 2010 05:10 PM
99A4NOW
Apr 6, 2010 03:47 PM
pstanley54
Sep 21, 2009 08:45 AM
