A3 1.9 TDI starting problem
Old Feb 4, 2006 | 04:32 PM
gix's Avatar
gix
Default A3 1.9 TDI starting problem
Hi,
I have an A3 1.9 TDi (98 Year) My problem is that on a morning it is really bad at starting I have changed the glow plugs which helped a little but it is still bad at starting first thing
When it has been running it starts no problem
The glow plug light only stays on for a split second it seem to me as if it is not long enough to heat the pluugs
Has antone got any suggestions
many thanks
gix
Old Feb 4, 2006 | 04:43 PM
dankhound's Avatar
Default RE: A3 1.9 TDI starting problem
Check for carbon buildup in the intake passage after the egr valve.
Old Feb 4, 2006 | 05:37 PM
gix's Avatar
gix
dankhound
Thanks for your reply wher would I find the egr valve??
gix
Old Feb 12, 2006 | 02:03 PM
dankhound's Avatar
On the firewall side of the engine. REmove the intake hose that goes into the intake manifold. Look inside and there is a valve kinda like a throttle. That should be able to be moved freely. And there shouldnt be a buildup of black stuff all around it. If there is your intake and egr are all carboned up.
Old Feb 12, 2006 | 02:24 PM
techbod's Avatar
glow plug relay a big possible seeing as its not warming up long enough
[IMG]local://upfiles/12092/B50B0F7D0461407591A5ED154E6B6BAC.jpg[/IMG]
Lourenstien
Oct 30, 2012 07:49 PM
bradwall96
Apr 25, 2011 05:10 PM
PaulA4
Feb 20, 2007 06:55 PM
lhayes
Jun 30, 2006 09:20 AM
PaulA4
Mar 9, 2006 04:30 PM
