A3T not firing on cylinder 4....Help
Hi, the car idle like a diesel tractor, I unplugged the coil one at a time while the car was idling and found that there is no change when I unplugged coil nr 3, I replaced the spark plug, no change, swopped coils 2 and 3 around but the fault didn't move to cylinder 2, so the coil seems to be fine, anyone have advise on the next step?
Sorted out, it was the power output stage module! New issue: I removed the cat, saw that you should modify the post cat O2 sensor with non-foulers, the problem is that my car only have one O2 sensor before the cat, what now?
