A4 1.9TDi cutting out!!!
Old Mar 17, 2006 | 08:15 PM
Stevel's Avatar
Default A4 1.9TDi cutting out!!!
Hi, I have recently bought an AUDI 1.9TDi 110 bhp model year 1997. I have realised that under load (ie:- in excess of 3000rpm) the engine holds back for a couple of seconds then the power comes back. If you keep the accelerator down it will keep repeating this fault. It only does this under load and feels like a rev limiter cutting in/out, (but obviously not that). It has 128000 miles on the clock. Any ideas? would be muchly appreciated.
Thanks in advance!
Old Mar 19, 2006 | 03:23 AM
shappie's Avatar
Default RE: A4 1.9TDi cutting out!!!
check turbo pressure
Old Mar 20, 2006 | 05:52 PM
Stevel's Avatar
Many thanks for your advice. I was thinking Turbo related too but was in denial. Do you know if this pressure check can be done at a general garage or will it be at a main dealer only? Should it be the turbo would you think it would be not advisable to buy a second hand turbo unit?
Thanks again!!!
Old Mar 25, 2006 | 02:40 PM
dankhound's Avatar
Sometimes its a problem with the wastegate control valve and the turbo is ok.
Old Mar 25, 2006 | 08:23 PM
Stevel's Avatar
Thanks very much. I have also been advised that it could be the air flow mass sensor. Do you know of the probability of it being this? Aparently it's a common fault?
Thanks any advice is muchly appreciated.
Old Mar 25, 2006 | 08:33 PM
techbod's Avatar
hmmmm could be fuel cut off solenoid
[IMG]local://upfiles/12092/C43478164E7C4F1888CDAF2559C67668.jpg[/IMG]
Old Mar 25, 2006 | 08:39 PM
techbod's Avatar
[IMG]local://upfiles/12092/57F8F4AB2CA04B8AB9CBCBD47A52EC09.jpg[/IMG]
Old Mar 26, 2006 | 04:28 PM
Stevel's Avatar
Thanks very much, I will keep this in mind. Yesterday I took out the air mass sensor to retrieve the part number and while I was at it I cleaned it up a bit. Not sure until tomorrow, but I think it has cleared the fault for now. Or maybe wishful thinking ha?
Thanks for your time, much appreciated. Thanks alot!
Old Mar 26, 2006 | 10:37 PM
dankhound's Avatar
The mass airflow is a common problem. Unpluging it will result in the ecm using a predetermined set of values for its input which should result in an engine that runs better with it unplugged.
Old Mar 27, 2006 | 08:32 PM
Stevel's Avatar
Cheers, it has definately rectified for now. I will purchase a new one in due course. Credit to forum!
