A4 overheating Please Help One cold One hot
Old Mar 26, 2008 | 12:43 AM
kwmcfp's Avatar
Default A4 overheating Please Help One cold One hot
Hello everyone,
My sons 96 A4 is getting close to the H on his temp gage I checked the hoses and the drivers side is hot and the pass is cold the heat works well.. How should I go about repair.
Thank you in advance. My A6 4.2 is over 150k and running strong!!
Kevin
Old Mar 27, 2008 | 06:33 PM
mattadams21's Avatar
Default RE: A4 overheating Please Help One cold One hot
most likely a thermostat, you might wanna change the timing belt and water pump , as the parts are right there. good luck
Old Mar 27, 2008 | 11:53 PM
kwmcfp's Avatar
Thanks,
The guy who replaced all the above used the green antifreeze I think it clogged the radiator!
Thanks for your help!
Old Apr 20, 2008 | 04:17 PM
kwmcfp's Avatar
I got it apart and the timing belt was so loose that I could easily turn the water-pump pulley by hand this could this have been enough to keep it from moving the antifreeze?
How tight should the belt be? 90% twist? Do you think I should still replace the pump and thermostat? They were replaced at 113000 has 173k on it now.
Thanks for the insight.
Kevin
dom_mewes
Feb 11, 2013 05:23 PM
ericcota2003
May 12, 2010 10:03 AM
ainarssems
Feb 5, 2008 11:19 PM
screech
Dec 10, 2006 05:39 PM
