a4 quattro rear system
Old May 1, 2008 | 09:57 AM
Isilus's Avatar
Default a4 quattro rear system
helloo.. well my bro crashed my car against a sidewalk ... but i dunno how to check if the rear is ok the rims seems to b ok tou... i drove it for a mile to check and i couldnt find any issue other than a little lag on response... please is there a way i could check if the damage was only to the rims
Old May 1, 2008 | 09:58 AM
Isilus's Avatar
Default RE: a4 quattro rear system
btw its AWD quattro ><
Old May 1, 2008 | 12:36 PM
SAudi's Avatar
you may have a bad wheel bearing coming on, that about it unless it was hard enough to bend a rear control arm, raise up the car and check out the arms and sway bar and with the hit wheel up shake it at 9 and 3 to see if theres any play. and lastly dont let your brother drive your car.
Old May 1, 2008 | 05:38 PM
Isilus's Avatar
lols tnx for the reply... well aprntly i havent noticed untill i raised the car... that my wheel seems to be like moved to the front side of the car.. its like it used to have a gap of around 3" from the door now it haves like 1"..... and the balljoint is like bent... so .. u guyz think i can change that on my own or have the stealership do it for me... ><
nd btw.. yeh mi bro aint driving my car no more ahah he aint even driving a bike till he pays off my car damage awhhawh ><
Old May 1, 2008 | 07:39 PM
SAudi's Avatar
you might need alot of pb vlaster to get the corrosion off but i think you can do it, not a hard job, think youll need a new upright and lower control arms. also make sure the cv boot isnt torn and the axle isnt bent, also ive seen that when something is bent (ie: control arms you need a torch to cut them off.
Inferno451
Jul 23, 2015 01:15 PM
moneyfresh
Sep 3, 2012 04:53 PM
alstein
May 8, 2009 02:17 PM
dave80jc
Jul 7, 2006 11:55 PM
