A6 Fuel Filling Problem
Old Feb 22, 2009 | 11:17 PM
GBaker's Avatar
Post A6 Fuel Filling Problem
2004 A6 3.0: The car will frequently not accept gas although tank is near empty. The filler neck will not drain after perhaps accepting a quart of gas. "Bouncing" the car, parking at a pump on an incline or flat surfaces makes no difference. Once I drive the car around the block a few times and retry - even at the same pump -it acts normally and I can fill up. No gas odors, no other symptoms. Is this a vent or carbon canister problem. Don't understand the intermittent nature of it. I've asked multiple garage attendants and they look at me like I'm crazy. Suggestions anyone?
Old Feb 23, 2009 | 02:29 PM
bigern45's Avatar
Sounds to me like the check ball is getting stuck in the tank full position and then when you drive it around it is jarring loose, making the fill process operational again...my b5 s4 was doing that at one time...i forced as much gas as possible and drove it for a few days...next fill up, problem was gone and has never happened again....with yours it sounds more frequent and so youll probably have to get a filler tube for the gas fank...just make sure it includes the check ball...
Old Feb 23, 2009 | 04:32 PM
zippy_gg's Avatar
If you hear a wooshing sounds when you open the gas cap then you have an issue with the charcoal canister (probably clogged up). If not then your issue is elsewhere.
pete7
Apr 12, 2021 12:16 PM
junya
Nov 19, 2008 09:40 PM
mojo5436
Sep 9, 2008 09:33 PM
ADubyaD
Aug 26, 2007 10:10 PM
b_coulombe
Jan 10, 2007 12:26 AM
