A8 Help Please
Old Aug 23, 2011 | 09:30 PM
ADS's Avatar
ADS
Default A8 Help Please
Hi-
I'm new to the forum & Audi ownership. I appreciate any input.
I have a 2008 A8 4.2V8. Recently had 55K service after 9K miles my engine light popped on. After driving a bit it began flashing and the idle and ride at low speeds was rough.
I contacted my mechanic and he advised not driving. I used my Ross-Tech CAN and got some faults in the engine. As listed below.
5 Faults Found:
005491 - Left Engine Mount Solenoid Valve (N144): Open Circuit
P1573 - 004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 19
Mileage: 81302 km
Time Indication: 0
Date: 2011.04.05
Time: 11:11:48
Freeze Frame:
RPM: 201 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 48.0°C
Temperature: 33.0°C
Absolute Pres.: 980.0 mbar
Voltage: 10.541 V
008569 - Bank 2; System Too Lean off Idle
P2179 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 2
Fault Frequency: 2
Mileage: 101761 km
Time Indication: 0
Date: 2011.08.17
Time: 14:16:41
Freeze Frame:
RPM: 1970 /min
Load: 52.1 %
Speed: 24.0 km/h
Temperature: 94.0°C
Temperature: 52.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.589 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 102039 km
Time Indication: 0
Date: 2011.08.18
Time: 15:20:40
Freeze Frame:
RPM: 693 /min
Load: 45.9 %
Speed: 3.0 km/h
Temperature: 95.0°C
Temperature: 66.0°C
Voltage: 13.335 V
000773 - Cylinder 5: Misfire Detected
P0305 - 001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 102039 km
Time Indication: 0
Date: 2011.08.18
Time: 15:20:40
Freeze Frame:
RPM: 693 /min
Load: 45.9 %
Speed: 3.0 km/h
Temperature: 95.0°C
Temperature: 66.0°C
Voltage: 13.335 V
004874 - Cylinder Disabling
P130A - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 102172 km
Time Indication: 0
Date: 2011.08.18
Time: 20:16:02
Freeze Frame:
RPM: 667 /min
Load: 35.7 %
Speed: 0.0 km/h
Temperature: 102.0°C
Temperature: 39.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.462 V
Readiness: 0000 0000
My mechanic thought it might have been a cylinder coil and replaced without success. Now he is considering a fuel injector issue. Can anyone help in decifering these codes and offer some direction?
Thanks in advance
Adam
