ABS/ESP
ABS/ESP ITT Mark 20[/align]Exploded view[/align]
Rotor for rear right speed sensor
â—†Rotor is welded to wheel hub
â—†Removing and installing: [/ul][/ul]
Rear right speed sensor -G44
[/ul]
Rear left speed sensor -G46
[/ul][/ul]
Rotor for rear left speed sensor
Handbrake warning lamp - K14
â—†Fitting location: in dash panel insert [/ul]
ABS warning lamp -K47
Brake system warning lamp -K118
â—†Fitting location: in dash panel insert in driver information system (DIS) [/ul]
Traction control system/ESP warning lamp -K86
â—†Fitting location: in dash panel insert [/ul][/ul]
Brake light suppression relay -J508
â—†Fitting location: in 13-pin relay carrier behind driver's storage compartment [/ul]
Brake light switch (F)
[/ul]
Rotor for front left speed sensor
Front left speed sensor -G47
[/ul][/ul]
ABS hydraulic unit -N55 with ABS control unit -J104
â—†The hydraulic control unit comprises hydraulic pump -V64, hydraulic unit -N55 and control unit -J104
[/ul]
Rotor for front right speed sensor
Front right speed sensor -G45
[/ul][/ul]
Longitudinal acceleration sender -G251
â—†Vehicles with four-wheel drive only
â—†Fitting location: A-pillar on passenger`s side
[/ul]
Brake pressure sender -2- -G214
[/ul]
Brake pressure sender -1- -G201
[/ul]
Brake pressure solenoid trip switch -F84
â—†Brake servo assembly must be replaced if solenoid is defective [/ul][/ul]
Brake pressure solenoid valve, in brake servo -N247
Brake fluid level warning contact -F34
Lateral acceleration sender -G200
[/ul]
Yaw rate sender -G202
[/ul]
Traction control system switch -E132
â—†Fitting location: on centre console [/ul]
Steering angle sender -G85
[/ul]
Handbrake warning switch -F9
â—†Fitting location: on handbrake lever unit [/ul][/ul]
[IMG]local://upfiles/12092/E69C746BE430465B90CEAD429F7B6B1D.jpg[/IMG]
