ABS Pulsing under light braking
Old Jun 10, 2005 | 02:25 PM
philbo1999's Avatar
Default ABS Pulsing under light braking
I have a 1999 S4 Avant 2.7T. For some months now the ABS seems to be activating when braking gently to a stop. There is a distinct clonk, clonk, clonk which you can both feel and hear. Sounds like it is coming from the front wheels. My local Audi dealer could not fix it due to the fact that there are no error codes! They tried new wheel sensors but they had no effect. The system has been bled and new discs and pads have been fitted. The ABS pump may have been the problem so I sent it off to be refurbished. Still no joy. I read somewhere that you have to use a VAG tool to bleed these pumps but since my model was before ESP was introduced I don't see the option to bleed using VAG-COM. Any help would be greatly appreciated.
Old Jun 10, 2005 | 03:50 PM
hb972.8q's Avatar
Default RE: ABS Pulsing under light braking
did you try new abs sensors?
Old Jun 10, 2005 | 04:32 PM
philbo1999's Avatar
The dealer tried new sensors but the problem remained.
Old Jun 11, 2005 | 07:40 PM
hb972.8q's Avatar
ORIGINAL: philbo1999
how new are your tires. worn tires have an effect to
Old Jun 12, 2005 | 07:24 PM
BFlan2001's Avatar
did your dealership replace all four sensors? if it happens just before coming to a complete stop (~5mph), then that definitely sounds like an abs sensor. sometimes they aren't bad, but they're just installed incorrectly (not seated quite right)
Old Jun 15, 2005 | 01:32 PM
Mums's Avatar
check the rotors for any type of damage?
Old Mar 5, 2006 | 11:29 AM
joe_miller01's Avatar
I unfortuneately, have the same problem on my 99 A4 2.8. I have yet to see the root cause on what fixed the problem from someone. Anyone finally get this problem fixed?
Old Mar 13, 2006 | 05:10 AM
cdmx's Avatar
Faulty ABS control unit?
Old Mar 13, 2006 | 05:11 AM
cdmx's Avatar
ABS light on?
Are you getting any DTC's?
Old Mar 14, 2006 | 04:39 AM
pznuttz's Avatar
do you have the same size tires all around and also what size wheels do u have on the car
