AC condenser fan works, not sure what in the system is broken
The car is a 1999 A4 quattro avant 1.8T.
The AC runs very cool when the car is moving but does not when stopped. The AC condenser fan does not operate.
I hooked up the ac condenser fan directly to the battery. It spun wobbly at first, then corrected itself and ran smoothly. A piece of the plastic turbo housing was cracked and had been down in the fan.
In my car I see the wires from the condenser fan connected by a single connector and then running directly into the body of the car towards the fuse box - there is nothing like a control module apparent under the hood.
I checked every fuse and they are all good. The only spots where there were not fuses where there could be were the two for the stability system - which I do not think would apply here.
What am I missing here, where is the broken link that is not turning on or powering the AC condensing fan?
I do not have a bentley manual or anything, so if someone has access it would be appreciated.
Fontanel
06-02-2012 01:38 PM
tofast2belast
04-06-2012 07:42 PM
derZeck
02-22-2012 02:53 PM
paintballcs
12-23-2009 08:26 AM
