Aftermarket true HID replacement for H4 Hi/Lo Bi Xenon
Old Dec 6, 2008 | 01:05 PM
mschaefer21's Avatar
Hey i got a 2003 1.8t a4 and i wanted to upgrade the lights to a Bi-Xenon 8000k hi/lo .. i dont know much about lights ..but would they fit? and whats the H4 stand for infront of the names of lights?
Old Dec 6, 2008 | 01:23 PM
oh and i will find some for like 300 bucks and other on ebay that say there the sme thing for like 80 bucks..so i am a lil congused any help?
Old Dec 6, 2008 | 01:25 PM
zippy_gg's Avatar
H4 is a bulb that provide both hi and lo beams, an outdated technology still found in many cars and motorcycles out there.
8000k will deliver a light on the blue side and not provide as much usable light as a 4300K. If you do a lot of night driving you want to reconsider.
Old Dec 6, 2008 | 01:34 PM
is the Bi-Xenon hi/lo 4 bulbs or just 2 that work on settings of hi and lo
Old Dec 7, 2008 | 09:08 AM
RASinPGH's Avatar
These forums have been a great help as I learn to repair my old 00 A4 myself.
I am now beginning the investigation of converting my 00 A4's halogen to HID. I have read that the lens can melt if I change only the bulb/ballast mechanism. Is this correct?
Old Dec 7, 2008 | 10:53 AM
phoenixlegend's Avatar
Thumbs up Bi-Xenon H4
Hi everyone:
The H4 is a single bulb unit per side, so a total of 2 bulbs per vehicle. I'm not sure what the A4 has, but if the halogen bulb says H4, it will be a H4 configuration which is Hi/Lo beam in one single bulb, 2 bulbs per vehicle. I have been driving my 1990 90 Quattro 20V with the vvme Bi-Xenon H4 for a few weeks now and it is definitely better than the halogen H4. However, to get the best light pattern, I strongly recommend switching over to an Euro H4headlight rather than the DOT version which is horrible. I switched over to Euro H4 right after I bought my 90 Q20V. Now, for A4, I don't know how the light pattern is so you have to figure it out on your own. Like I've mentioned before, for the price, vvme is really inexpensive, under $100 and so far they work well. If you have money to spare, go for the German's HID kit, German y products are always better and last longer. I don't plan on keeping my 90Q20V for more than a few more years so the inexpensive vvme fits the budget even though I don't like to buy anything that says Made In China. As far as melting your wires and lens goes, I think if you use the high watt halogen bulbs, you may have a problem there but true HID kit, I don't believe so. I used to run Osram 80W/85W H4 in my car and I never encountered any melting problems. I have used non-OEM HID conversion kits since they first came out(over $1,000 way back ) and I love them ever since. Go buy the true Bi-Xenon, it will help you see better. Keep the colour temperature value close to 4300K rather than the higher value like 8000K and beyond. the lower the K value, the more true light output it will provide. Now, for the Cool Factor , perhaps the higher K value, the cooler it looks but lesser light output it will have. Good luck and go HID
Old Dec 7, 2008 | 12:40 PM
RASinPGH's Avatar
Thanks, Phoenix
I appreciate the informantion. I'm way too old for cool, really just trying to get a better lighting source, so I'll stick to the 4300 area. I have also just come across the potential need to beter focus the light when switching from halogen to HID. The term used was "bedazzling" (and here, I thought that was just a Lil Bush term) which referred to an unfocused pattern. Are new projectors also called for? LLTEK's appear to be similar to those already installed.
Old Dec 7, 2008 | 04:16 PM
  #18
afstud6900's Avatar
Banned
the audi a4 is just a low beam, youll need a h7 bulb http://ddmtuning.com/hidkihidbuhi.html they have the best kits and they have 55 watt kits which give the most light possible do that youll never be dissapointed with them.
Old Dec 7, 2008 | 07:23 PM
  #19
i just took a look at http://ddmtuning.com/hidkihidbuhi.html and in teh first kit..does that include everything you need cause its only 55 bucks..it just seems to good to be true for HIDS..lol
Old Dec 7, 2008 | 07:37 PM
  #20
like what is the difference then between this kit http://www.customstreetdesigns.com/5069-CF-HID-H9.htm and the kit that is linked in the above post? this one is 150 and the other one is madd cheap.. is it not the real deal?
