Air Conditioning
Old Jun 20, 2006 | 01:06 PM
beefski's Avatar
Default Air Conditioning
I have a 96 A6 wagon with the 12v V6. My A/C is no longer working (cold).
When I open the hood the condenser (looks like a radiator) has what appears to be a stain from a leak.
Can a condenser be repaired? Is it worth repairing or easier to replace?
Is there anything unique to the Audi A/C system.
Thanks.
Old Jun 20, 2006 | 02:17 PM
techbod's Avatar
Default RE: Air Conditioning
the condenser can be repaired but at a cost near to a new unit so not viable ( fit a new or refurbished unit) are you sure its that where the leak is from/if the system charged up?? or could it be it just needs charging, the system can be pressure tested at a garage that works on A/C systems
Old Jun 20, 2006 | 02:20 PM
beefski's Avatar
Is there anything "special" about the a/c system in audis?
There is a distinct stain on the condenser that runs down. When I first purchased the car, I tested the a/c and it was cold. It has not worked since.
Old Jun 20, 2006 | 02:25 PM
techbod's Avatar
nothing special mate same as most cars it could need a recharge but the only real way to check it is to have the system pressure tested
they use a dye to find leaks
Old Jun 20, 2006 | 02:27 PM
beefski's Avatar
Why would the system need a re charge if there was no leak.. Aren't a/c systems a closed loop. The refirerant does not get used up, right?
Old Jun 20, 2006 | 02:31 PM
techbod's Avatar
it does leak out over time same as a fridge in the house the gas depletes all metal is porous to some extent that's why they need re-gassing approx every three os so years
Old Jun 20, 2006 | 02:42 PM
beefski's Avatar
Thanks avant, I'll have to get it to a shop for a check up.
Can't go another summer without A/C.
Old Jun 20, 2006 | 08:43 PM
audinationman's Avatar
it needs to be recharged every once in awhile, thats costs a pretty penny but fixes most a/c problems
Old Jun 22, 2006 | 05:49 PM
SAudi's Avatar
im kinda pissed with the older 12v engines. imnot too sure about the a6 model but my a4 from the same time has a weird low side valve. you cant do it yourself with a kit, most shops cant do it, and even though audi said they can i dont htink they can. i was in yesterday getting my system charged and it didnt do anything, still hot and i got charged 250. later i checked the pressure in the system and it read 0psi. and i know there wasent a leak.but then again when a brick goes through your grille who knows.
lumpyd
Jun 18, 2013 09:36 AM
1.84life
Jun 20, 2008 01:21 AM
godowninflames
Apr 21, 2008 09:26 PM
Robsa4
Oct 7, 2007 01:44 AM
S4Goose
Jul 2, 2007 06:33 PM
